Optional 3rd parties for model-based tracker module
ViSP model-based tracker module may use several optional third-party libraries.
Recommended optional 3rd parties
You don’t need to install all these dependencies. The next table gives the recommended library that should be installed to enable some ViSP capabilities.
| 3rd party | Capabilities | |||
| ++ | ++ | ++ | Keypoint feature tracking |
Other optional 3rd parties
The following table shows the capabilities that could be obtained with the other optional 3rd party library.
| 3rd party | |
Capabilities |
| + | + | + | VRML CAD model reading | |
| + | + | + | Augmented reality and model-based tracker visibility | |
| + | + | + | MBT with depth feature |
Deprecated optional 3rd parties
After releasing ViSP 3.2.0 we introduce pugixml as a built-in 3rd party library. It replaces favorbly libxml2 3rd party library. As a consequence, there is no more need to install any 3rd party to parse xml files.
For those who want to continue to use ViSP releases up to ViSP 3.2.0 included, we give the instructions to install libxml2:
| ++ | ++ | ++ | Model-based tracker parameters setting |
