3rd_jpeg
jpeg 3rd party
Since ViSP 2.8.0 it is not useful to install this 3rd party if OpenCV is used in ViSP.
The libjpeg library is a C library provided by the IJG (Independent JPEG Group). It enables to read and write JPEG files. It can be downloaded from http://www.ijg.org/. It’s license allows to use libjpeg for whatever you want. ViSP is compatible with libjpeg 62 and libjpeg 80.
Hereafter we provide installation instructions for the following OS:
 logo-ubuntu-alpha  logo-debian logo-fedora logo-redhat centos-logo  logo-apple-alpha  logo-win-alpha
Ubuntu Debian Fedora RedHat CentOS OSX Windows
Ubuntu or debian installation
On Linux Debian or Ubuntu, the installation depends on the distribution. Since Ubuntu Precise 12.04 you may install libjpeg with:
sudo apt-get install libjpeg-dev
On prior distributions you might install one of the following packages::
sudo apt-get install libjpeg8-dev
sudo apt-get install libjpeg62-dev
Fedora, RedHat or CentOS installation
On Fedora, RedHat or CentOS you may install the library with yum:
su -c "yum install libjpeg-devel"
Mac OSX installation
On OSX you may install the package with homebrew:
brew install jpeg
Windows installation
Under Windows, you may build libjpeg from source code. Download jpegsr8d.zip file from http://www.ijg.org/, unzip in C:\my_path\jpeg-8c and follow the instructions provided in install.txt.
To resume, with Visual C++ 2010 you should run the following commands in a command prompt:
nmake /f makefile.vc setup-v10
Open jpeg.sln file with Visual C++ and build the solution.
In order to be detected by CMake, you should than add LIBJPEG_DIR environment variable which points to the folder C:\my_path\jpeg-8c containing the lib, bin and include folders.
We give bellow the changes that have been done in order to build libjpeg from source with Visual C++ Express 2010 on Windows 7.
In makefile.vc we replace the following line:
!include
by:
include C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Include\win32.mak
Tips and tricks
If jpeg is not detected during ViSP configuration step, you can create an environment variable called “LIBJPEG_DIR” and set it to the path corresponding to the folder containing the library.
