CMU 1394 3rd party
The CMU 1394 Digital Camera Driver is useful to capture images from a firewire device on Windows. This driver is released under the terms of the GNU LGPL v2.1 license. CMU 1394 is one of the optional 3rd parties supported by ViSP sensor module.
The driver is available from http://www.cs.cmu.edu/~iwan/1394/index.html.
With this driver, under Windows you can grab images from firewire cameras with vp1394CMUGrabber class.
Tips and tricks
Once installed, CMake should then detect CMU 1394 driver. If not, you have to set the CMU1394_HOME environment variable from where you can find “include/1394Camera.h”.
